heater help
Wed Jan 25, 2012 8:41 pm
by kc12305
ok for some reason in my sedan my key is off and out of my car all my consule controls are off and for some reason i cant figure out why my heater is still spooling hot air and then when i hit number 4 the heat blasts and well i cant seem to figure out how to turn it off ? any advice
Wed Jan 25, 2012 9:34 pm
Here's a thread about this issue:
http://civic-eg.com/viewtopic.php?t=22341
There's a fuse that someone removed to fix the problem.
Fri Jan 27, 2012 12:06 am
by kc12305
whats the fuse look like
Fri Jan 27, 2012 2:36 am
It's a fuse in the underhood fuse box. Check in your manual
Fri Jan 27, 2012 4:05 am
by kc12305
i dont have one the car never had one when i got it
Fri Jan 27, 2012 10:32 am
by andyc
you mean your missing that particular fuse already or the underhood fuse box has been moved??
Fri Jan 27, 2012 2:20 pm
by ALLMPGcivic803
just check on the back of the fuse panel it may have a diagram if it doesnt you can get online to find one or go to napa and have them look it up for you mine didnt come with manual either so i looked it up at napa
Fri Jan 27, 2012 4:49 pm
by kc12305
ok well the thing is and this sounds really wierd so bare with me , this moring i went out there and i replugged my battery back up and it didnt make any noise so i turn the car on and off and it did , BUT when i installed my sound system in it today and i drove around for 30 min tunning the sound i shut car off and it didnt make any heat or noise to any of yall think there is any corealation between the to
Fri Jan 27, 2012 6:26 pm
Sounds like maybe you moved some wires a little bit and fixed the problem? Maybe a wire was shorting to begin with.
Fri Jan 27, 2012 7:55 pm
by ALLMPGcivic803
x2 wires can sometimes get crossed i had a 94 chrysler lhs that i tried my first radio install on when i was 16 and i shorted some stuff out and my power door locks quit workin interior lights and the headlights wouldnt stay on after i turned the key off like they used to so you never can tell whats attached to that same loom
