- Sun Oct 02, 2011 6:21 pm
#275778
hey my name is keith i just got a 924dr ex civic 5spd and i am haveing problems with my heating controls the hot to cold works fine and the speed of the blower motor works on 1234 but the setting for the floor def and so on wont switch through the settings ive looke on line and its said to check the fuses and the heating control unit and the mode slector i have tried all of the above all fuses are good and when i tried the diff heater control unit it did the same so i went to the local junk yard and got a differnt mode control unit and i sill did not work so if anybody has anymore ideas for me to check please post of message me thanks
- Sun Oct 02, 2011 8:30 pm
#275794
Mode motor assembly sounds bad. Part #5 : http://www.bkhondaparts.com/index.php?p ... EATER+UNIT
- Mon Oct 03, 2011 1:42 am
#275847
I wouldnt get an electrical part like that from a junkyard. But anyways, plug it in and see if you can hear it attempting to move at all when you press the selection buttons on the climate control panel.
