- Thu Sep 29, 2011 5:59 am
#275211
Can i drive my car without my ac compressor. i have a d15b3. i want to get rid of the entire compressor unit. how do i do it?
- Thu Sep 29, 2011 6:04 am
#275213
yes you can but why would you take it out
- Thu Sep 29, 2011 6:31 am
#275215
The AC rounds on it's own circuit the belt is separate so can be taken out on it's own you can then also remove the compressor and pipping very simple job.
I live in the uk and not much need for AC so I pull it out of most my cars
- Sun Oct 02, 2011 4:02 pm
#275758
I run my AC more in the winter than summer. It is great for clearing moisture off the windows in damp weather.
Bet you have your share of that in the UK too.
Don't take the compressor nor the belt off, if you never turn the AC on, there is no load put on the engine, the compressor has almost zero drag if the AC clutch does not engage. When you want to sell the car, all the parts will be there. I avoid cars that have been stripped like that.
- Sun Oct 02, 2011 6:12 pm
#275776
x2
I have wished everytime I got a Civic that I had A/C. I have it on my WRX and would never remove it. The advantages of not frying in the summer and clearing windows in the winter way outway a "Clean bay" IMO.
I agree with Datsmart in not buying cars that have had P/S and A/C Removed. I turned down a good trade in my favor because of it.
2017 Chevy BoltEV DD |2001 Honda CRV SE
Datsmart wrote:I run my AC more in the winter than summer. It is great for clearing moisture off the windows in damp weather.
x2
- Fri Oct 07, 2011 1:00 am
#276575
i also plan on doing this, so removing the ac compressor wouldn't help me regain any power loss from using it? the compressor is still attached to my motor but i cut the belt off because it squeaks like crazy.
1995 DX EG8
Mild D15B7
..soon to be Y8 Mini Me
Mild D15B7
- Fri Oct 07, 2011 1:44 am
#276581
no, when the compressor is not engaged it spins freely.
I<3ferioEG8 wrote:i also plan on doing this, so removing the ac compressor wouldn't help me regain any power loss from using it? the compressor is still attached to my motor but i cut the belt off because it squeaks like crazy.
