- Sat Jun 25, 2011 7:15 am
#260908
I have a 1995 Civic EG, I dont have any CEL appearing on the speedo, I have removed the speedo to check if there was maybe a damaged bulb but it looks as if one does not exist.Does any1 have info on this please?
- Sat Jun 25, 2011 7:50 am
#260911
Not sure what your problem is. Is the Speedo not working?
- Sat Jun 25, 2011 7:57 am
#260915
well I know that the clusters vary but I am pretty sure my CEL is on the Temp/fuel gauges. Is there no bulb holder behind where the CEL should be?
- Sat Jun 25, 2011 8:35 am
#260917
what I would try and do is pull out your cluster and get a flashlight and see if you cant hold the light at an angle that makes it easy to see were it is. Or shine it on the back and if there is no bulb where it should be the flashlight should make it light up.
- Sat Jun 25, 2011 9:20 am
#260923
Mine is about where the circle is should be a brown or black bulb holder on the back 1/4 turn and it should come out. Then shine the flash light in each hole and look at the face. I think that I have a couple lights down there shift light and something else cant remember. Good luck not sure what else I can tell you to try
- Sat Jun 25, 2011 9:37 am
#260925
You need to use a site like photobucket to host your pics then you can put the image link into your posts and they will show up
here is a link on how it works
http://civic-eg.com/viewtopic.php?t=8381
