- Fri Jun 17, 2011 7:00 am
#259772
okay, no one fitted an oil cooler to your cars
lol. anyway then i will do a review on this product...
Hardware: this kit comes with clamps, hoses and fittings.
Estimated Time Taken: 1-2 hrs (depending if you gonna do it with oil drained or not)
Tools Needed: get all your wrenches (i worked in metric wrenches so i dont know what they are for other countries); hoist (makes things easier, you will see at the end why);light; and a few rags...
Installation: I have removed my aircon so therefore i had space to play with, if you want to keep you ac unit then there is ample space infront of your radiator (i woudnt do this as we have quite small radiators, choice is yours) . I then mounted the oil cooler to where the ac rad use to be, ran the pipes same way as the ac pipes ran and behind my intake manifold and down towards the oil filter. now that you have that sorted, you now have to carefully (if you want to re-use it) remove your old oil filter (i suggest you drain your oil before doing this, less messy), tighten up pipes that go into your oil sandwitch (before fitting brass fittings add some thread tape, just to be safe) and slot the sandwitch in position (where the oil filter use to go) tighten the adapter screw (nice and tight- do not overtighten). then fit your oil filter, AND REMEMBER TO CLEAN all oil that has dripped- so that if there is any oil leaking you can trace it quickly. refill your oil, you will need more oil as you have an oil coole rad to fill aswell.
N.B- CHECK AGAIN IF ALL FITTINGS AND BOLTS ARE PROPERLY TIGHTENED!!!
Now start up (stay in the car when being hoisted up so if there are any leaks you can immediately switch the ignition off) with a buddy checking under your car for any drips- shoudn't be any if you took your time and checked every fitting.
Testing you new oil cooler: to properly test this you will need a oil temp gauge , i do not have one however but if you know your car you will be able to feel a difference after continous hammering.
PRO'S- cooler oil temp, prolonging engine life (thats the only pro i care about) , looks good (not that i care).
CON'S- you have to fill one more pint of oil lol- thats the only con thus far.
well worth the $$$ spent
Spoon Sports
1995 Frost White EG9 SiR
