- Mon Nov 08, 2010 3:30 pm
#222114
when i removed my windshield those pieces "looked" like they just slide up.
Like Teal said there are a few plastic clips holding it to the body, which if i had to guess are probably fairly cheap from Honda.
I tried sliding them up but the plastic was so brittle it just broke anyways, so i would suggest just get a flat head screwdriver and CAREFULLY pry starting at the bottom closest to the hood hinges. Once it starts moving or breaks it comes off fairly easy.
My plastic clips were installed with the factory windshield and to my knowledge the car never received another windshield so they are from 1993-94 and were BRITTLE. I wouldn't try to save them. Would just cause you grief in the long run if they break with the new moldings on there.
My 2 cents anyways ;-)
