- Sat Apr 19, 2014 5:44 pm
#344761
Hello everyone Working on a D16Z6. 93 del Sol. After rebuild it was working great . until I had a no start. Finally got it back running but stuck on limp mode .already swapped computer. But still stuck on limp mode. Changed dizzy due to being a 1.5 and needed 1.6 I do have signal to computer it ohms good.new cap n rotor . new wires. Motor has only 300 miles. Checked map sensor ...good..the temp sensor ohms good and fan works.cleaned throttle body. Cleaned IAC valve and valve for cold start up on bottom of throttle body. Has new 02 sensor.replaced fuel pump.changed VTEC and solenoid gasket .I wire brush grounds. Check harness for shorts. I can't ground cable to adjust timing its only running on limp mode. I am puzzled.what can it be.?????
