- Sat Jan 16, 2010 10:44 pm
#168948
hi all,
my name is Johan, i live in southern Holland near Eindhoven.
i ame a honde civic eg hatchback enthusiast, draw to honda tuning by my brother who has a Del Sol b series 1.6 16v turbo. we both work on his racing project, wich is a honda civic ej2 coupé. all build for track racing.
i own a civic EG6, wich was in a poor state when i bought it. i stripped it clean and put it in a local bodyshop, where the whole body was de-rusted, new whaalarches welded in and all dents were taken out. its finished now and i ame rebuilding it now.
the B16a2 engine that was originalie in it was in a wors state the the body.
after running 260K and then being raped bij people who dont know how to properlie tune a car / engine, i took it out and put it on a shelf.
i had a b-series engine before i had a honda civic, wich was a B16B jdm typeR. this engine has little miles on it. so i put it in the eg6.
now the engine works fine, so do the brakes. my interior needs a little fixing before it is all done. but that will be fine in some time.
i will post my speclist for sofar as it is at this time:
engine:
b16b with stock intake manifold.
(i have ITB's wich will be installed in the upcomming summer.)
inovative motormounts.
injen airfiler.
msd spark plug wires.
exedy replacement clutch.
shortshifer.
4-1 header, 2,5" collector.
catalyst converter.
full 2,5" exhaust.
interior:
Spoon Sports steering wheel.
Spoon Sports shiftknob.
QSP 4poin harness.
kevlar bucket seats.
typeR shiftbooth.
black floor "carpet"
DIY home fab roll bar.
all other interior is stripped exept the doorpannels, dash, and middle console.
exterior:
Team Dynamics pro race 1.2
sir front lip.
Spoon Sports carbon fibre duckbill spoiler.
Spoon Sports carbon fibre mirrors.
mudguards.
suspension:
Spoon Sport front tower bar.
Spoon Sports bigbrake.
D2 coilover.
Brembo brakediscs with ferodo brakepads on the rear.
Buddyblub front camber kit.
D2 rear camber kit.
Stainless steel brakelines (DIY)
JDM integra type r front and rear anti swaybars.
ARS subframe brace.
function7 LCA's.
ICE:
pioneer radio.
few cheapass speakers, brand unknown...
(i like the motor sound more than loud music)
The future plans:
The plan: Run the eg6 with B16B, with EFI Hardware ITB'S and a Garrett Turbo. With watercooled intercooler and 3" exhaust. At 8.6 PSI (0.6BAR) of boost.
The parts i have gathared so far:
Skunk 2 megapower 3" stainless steel exhaust system.
Garrett gt2860RS.
EFI Hardware ITB's (with DIY plenum)
HKS SSQV dumpvalve.
Tial 38mm wastegate.
STRI dsd boost gauge.
STRI dsd oil temp gauge.
STRI dsd oil pressure gauge.
Powervamp 25 battery.
ACT Heavy Duty Clutch.
ACT lightweight flywheel.
And a big pile of small bits, wich i cant all remember at this time
a few of our racecar specs:
SPECS
Tranny
-b16a2 tranny
-s80 LSD
-Exedy stage 3 clutch
-b18c flywheel
-Stainless steel braided clutch hose
Engine
-B18c JDM
-Overhauld head
-Milled head
-OMI-performance high compression valves
-OMI-performance valve springs
-OMI-performance titanium retainers
-OMI-performance camgears
-Stock cams
-BLOX intake
-68MM ALU Throttlebody
-12tune Cold air intake
-SRS 4-1 header
Engine bay and fueling
-STR engine mouts
-ATL fuelcell 40 Ltr
-Bosch external fuelpump
-FIA approved fuel lines
-FIA approved couplers
-FIA approved fuel filter
-12tune fuel rail
-QSP fuel pressure gauge
-12tune ALU radiator
Suspension
-Biesheuvel KNAF approved rollcage
-OMI-performance SPEC SR suspension 14k front, 10k rear
-12tune camber kit front
-D2 toe kit rear
-D2 camber kit rear
-Energy suspension bushings
-12tune front and rear strutbar
-Megan racing H-brace
-DC2 Integra 4x114,3 undercarrige
-Rota circuit 8 with toyo r888 tires
Brakes
-D2 Big brake kit 286 front 6 pod
-Stainless steel braided brake hoses
-Wilwood brake balance controler
-Stock rear brakes with ferodo ds2500 pads
-1 inch MBC
Exterior
-Buddyclub 1 bodykit
-Custom rear diffuser
-Eagle diffuser
-Lexan side windows
And much more....
TO DO'S
-Big brake rear
-Stiffer chassis
-Buddyclub cams
-Retune
-Wider front fenders
-Buddyclub front chamber kit
-Front canards
-Front diffuser
greetz
johan
engine:
injen airfiler.
shortshifer.
catalyst converter.
full 2,5" exhaust.
interior:
QSP 4poin harness.
typeR shiftbooth.
exterior:
sir front lip.
mudguards.
suspension:
D2 coilover.
D2 rear camber kit.
ARS subframe brace.
function7 LCA's.
ICE:
pioneer radio.
The future plans:
Garrett gt2860RS.
HKS SSQV dumpvalve.
SPECS
Tranny
-b16a2 tranny
-s80 LSD
-b18c flywheel
Engine
-B18c JDM
-Overhauld head
-Milled head
-Stock cams
-BLOX intake
-SRS 4-1 header
-STR engine mouts
-12tune fuel rail
Suspension
-D2 toe kit rear
-D2 camber kit rear
Brakes
-1 inch MBC
Exterior
-Eagle diffuser
-Lexan side windows
And much more....
TO DO'S
-Big brake rear
-Stiffer chassis
-Buddyclub cams
-Retune
-Front canards
-Front diffuser
greetz
johan
