Technical Topics specific to the Del Sol body - NOT where you post pics/build specs of your car.
By thecrow
#49151 i have a stock 1997 del sol s and i wanna do the motor swap deal and go b series. will any b series enginework? and will it hook right up harness wise or will i have problems? i want to have a pretty easy swap.
By asianrob
#49160 any B-Series motor from 90-01 integra will work
any B-Series transmission (hydrolic) will work 92-01
By flyinryan122
#49178 But the stock wiring harness (sohc harness) wouldnt have the plugg for a knock sensor, if you got a motor with a knock sensor in it.
and of course you will need b-series axles
By LowTEC-Derbo
#49179 being from 92-95 you have the easiest chassis to swap a B into.
You will need to use your stock harness and add a few wires if you do not have vtec already. If you do, great! you will just need a knock sensor to be added.
You will need ECU, mounts, shifter linkage, header, axles from a B series. The Engine itself and the tranny. Besides that, it is a pretty straightforward job to drop a B.
By thecrow
#49280 thanks for the help so far guys
By thecrow
#51841 what about obd1 or 2 ? do i have obd 2? and what b series are obd2? and i dont have vtec, should i stay away from it if i am going the cheaper route? im still a noobie on this stuff
