Adjusting the toe angle.
Sun Jan 12, 2014 7:17 am
by jackster.rap
So i just bought a 95 dx coupe, and its already slammed. It has adjustable coilovers but the guy said i needed a camber kit to save the tires. I recently read the article on here telling me that i did not need it, just needed a proper toe angle. How do i get that proper angle?
Mon Jan 13, 2014 12:05 am
by TrailerTrash
you have to either take it to a shop that does alignments or adjust the toe yourself by using a tape measure and adjusting the tie rods. it can be very tricky but it can be done. you can find videos on youtube
most people confuse toe wear with camber wear
Thanks
Mon Jan 13, 2014 1:44 am
by jackster.rap
Thank you for the help, gonna star making calls tomorrow.
Mon Jan 13, 2014 2:15 pm
I tried myself once... It's not easy. But yeah, it's toe-out that chews up the insode of your tires. Negative camber will have little impact on tire life compared to a bad toe-out alignment.
i should have asked
Mon Jan 13, 2014 6:18 pm
by jackster.rap
So i should asked, do i need to hqve the shop do my back tires as well? Or is it just my front that needs to be adjusted? Sorry if that is a stupid question. Im just trying to get all the info befor i take it to a shop.
Re: i should have asked
Mon Jan 13, 2014 7:35 pm
by egsedanguy
jackster.rap wrote:So i should asked, do i need to hqve the shop do my back tires as well? Or is it just my front that needs to be adjusted? Sorry if that is a stupid question. Im just trying to get all the info befor i take it to a shop.
I belive the front is all you need. The rear only have camber adjustments. But i would recommend doing all the wheels just in case there is somthing bent in the rear.
Mon Jan 13, 2014 8:49 pm
Rear also has a toe adjustment. I'd get a 4-wheel alignment after raising/lowering suspension.
thanks again guys
Mon Jan 13, 2014 9:53 pm
by jackster.rap
Thanks again, you guys have been very helpful.
Mon Jan 13, 2014 11:08 pm
by HeikDiesel
teal_dx wrote:Rear also has a toe adjustment. I'd get a 4-wheel alignment after raising/lowering suspension.
x2. Rear trailing arm bolt is in a slot and can be loosened to adjust toe
Tue Jan 14, 2014 12:35 am
by egsedanguy
HeikDiesel wrote:teal_dx wrote:Rear also has a toe adjustment. I'd get a 4-wheel alignment after raising/lowering suspension.
I never knew this. but great to know.
Thu Mar 20, 2014 10:52 pm
by kelz781
That rear sub arm on the trailing arm is the compensator arm for toe adjustments , I deffinatly recommend ordering a pair before the alignment . Just in case there bent a bit you won't get the proper toe (never no what accidents it's been in) *curbs cough cough*
Thu Mar 20, 2014 10:54 pm
by kelz781
Also I recommend upper control arms , the more the joint is worn the more camber ware will appear on the tires
