- Fri Jul 26, 2013 4:32 pm
#334735
It's slowly getting worse. I don't have the tools to cut and weld. What else can I do
- Fri Jul 26, 2013 4:33 pm
#334736
- Fri Jul 26, 2013 4:35 pm
#334737
you can send it with heavy grit, hit it with rust prevent. paint, body filler it, and paint it. but it will come back.
or you can pay someone a hefty chunk of change to cut and weld in new panels.
2007 Honda Civic Si
- Fri Jul 26, 2013 5:11 pm
#334738
FG2_Andrew wrote:you can send it with heavy grit, hit it with rust prevent, body filler it, and paint it. but it will come back.couldnt have said it better
My 1992 SOHC Turbo Hatch
- Fri Jul 26, 2013 5:22 pm
#334739
you could have because i typed "send" and not "sand"
teal_dx wrote:FG2_Andrew wrote:you can send it with heavy grit, hit it with rust prevent, body filler it, and paint it. but it will come back.couldnt have said it better
2007 Honda Civic Si
- Fri Jul 26, 2013 5:23 pm
#334740
also, OP:
passenger side looks salvageable if you hit it NOW. drivers side is gonna need cut and welded.
2007 Honda Civic Si
- Fri Jul 26, 2013 6:50 pm
#334742
Seeing the rust creep up from behind the plastic rocker cover is never good.... It can get pretty ugly behind there. Check out the How to fix your Honda rust thread. I had some rust creeping up from that area and I took off the rocker cover and stabbed the area behind with a screwdriver and it went right through until it looked like Swiss cheese.
- Sat Jul 27, 2013 12:31 pm
#334783
I was in exactly the same rusty boat as you. i chose to save it and glad i did man. unless the rest of the car is in sad shape its worth it to save
