By madhatchride
#330641 so ive tackled more with putting this eq coupe togther then i thought i was because after getting a swap and buying it from a well known shope spending gobs of money i still am running into trouble the car is poping like and i cant tell if it a strut or what i know its not the axles they are brand new along with my whole drive train but when the car is moved even just slightly it pops
By nicksdelslow
#330646 More detail needed. Moved how rolled forward backward or when a crrtain corner is moved up and down. Where does it pop.
Check the small stuff make sure all ur washers are on ur strut pins. Make sure all the nuts and bolts are tight.
By madhatchride
#331029 when i role it mainly
