- Tue Jul 31, 2012 12:58 pm
#312379
It clicks right when you start to move forward but not if you release the clutch in neutral, right? If so, I've heard this before. It could be play in your CV joints where there is a little slop and the click is the metal pieces inside contacting. If it usually happens when starting out in 1st going forward AFTER you just went in reverse, then I bet this is it. Once you go backwards, the CV joint will be turned in one direction. Then when you go forward, it will rotate in the other direction but because there is a little bit of play, it will make a "click" noise when the parts inside move across the area of play and contact the next metal piece.
It's hard to describe but if you think about your car on a jack and you're putting the front wheel on but the lugs aren't on yet, when you grab the tire and spin it fwd and backward, you'll get play between the wheel studs and the holes on the rim. But it only happens the first time you rotate it fwd after rotating it in reverse. Same concept with the CV.
