- Wed Dec 15, 2010 7:15 pm
#228080
clicking sounds like the battery could be about dead, try hooking up to a running car w/ jumper cables and give it a try.
Unless it is just one click and then nothing else, that sounds like a dead spot in your starter. Try taping it w/ a hammer and see if it starts. If so, you can do the hammer trick for a little while until it dies completely. This is because there are 4 contacts around the starter that wear down and one or two may be completely worn. Tapping can help it turn a little so that one of the good contacts is able to connect.
