fuel pump replacement
Thu Jul 08, 2010 7:38 am
by platnuim86
So I did some searchin on the forum and it looks like my fuel pump is goin out I get a cel #43 replaced my fuel filter no dice . So was wondering how hard is it to change can I just pull up the back seat or do I have to drop the tank out
need advise plzzz
Thu Jul 08, 2010 8:45 am
by platnuim86
. Now I have a code 41 also but don't under stand what that mean oxygen sensor heater???? Anyone know what that is
Thu Jul 08, 2010 1:14 pm
It's not common for a fuel pump to go bad. I'd check your injectors first.
http://civic-eg.com/viewtopic.php?t=10841
there you go, except yours will be easier if you use a stock replacement.
Try installing a different o2 sensor to see if the 41 goes away.
Thu Jul 08, 2010 3:10 pm
by platnuim86
Thanks teal ya I'm goin to try a new o2 cuz I unpluged it on the way home from work and it wasn't boggin around 3k anymore so that might be the culprite
Thu Jul 08, 2010 4:59 pm
by VerLee24
answer to your original question; you dont have to drop the tank. take the rear seat off, unscrew some nuts, unclip some connectors and hoses, remove fuel pump.
pick up a helms manual
