- Fri May 21, 2010 6:05 am
#195841
so i have a coupe with a b16a. it worked fine for a couple of months then one day it doesnt crank to start. i changed the battery and it wont crank or start. do you guys think its the starter?
- Tue May 25, 2010 10:50 pm
#196781
try regrounding your motor, if you just want to test for unsufficient ground you can use a jumper cable, using one color (red or black) clamp your starter on a mounting bolt or something just not the two places where wires already exist and run the other side to the neg batt terminal. if it starts like that get some amp wire, loom, and terminals make it look nice
- Wed May 26, 2010 1:50 am
#196809
does it make a 'click' at all when you try to start it?
