By Dirtymechanic87
#151969 i bought a fog light kit with a switch and wiring kit, but the switch is the three part switch with fog light being and the right. the problem is that my crusie control is in the right side of the switch. the left is the moon roof, and the middle is the lights dimmer. on the other side of the dash there is a empty slot next to the rear window defroster. the fog light switch is only for the right side of the switch and the empty slot is for the left. what can i do?
By Classiccarsrule85
#151993 flip the switch? that should do the trick.....im pretty sure you could just take a universal switch and use that instead.....normally those switches are for the left. i have one but not sure if it works im not using it if you want to make a offer also post pics since words are somewhat hard to understand at first
By usdmej1
#153391 damn
By project ej2
#156918 i suggest to flip the switch to..!!!
