- Mon Aug 17, 2009 9:30 pm
#138373
i dont know how to put my header on i dont want to mess up something im new at hondas can someone help me out a lil
jacktown1 wrote:i dont know how to put my header on i dont want to mess up something im new at hondas can someone help me out a lil
Start by taking off the heatshield on the old stock header.
Then go under the car, and unbolt the 2 bolts i think it is that hold the lower section to the cat.
Then unbolt the 3 bolts from under the car where the lower section of the old exhaust manifold and the upper section meet.
now go to the top and unplug the o2 sensor plug, and start pulling off the 9 nuts that hold on the manifold to the head.
Pull the mani out, pull out the o2 sensor, swap it into the new header, and put it all back together the same way you took it apart.
That should pretty much cover it, and before you do this, soak all of the nuts/bolts with pb blaster. it will save you many head aches.
Good luck
