Best HD settings to export your video for Youtube/Vimeo
Codec H.264
A codec is the format in which your video will be encoded. Different codecs have different features and varying quality. For best results, we recommend using H.264 (sometimes referred to as MP4).
Frame rate 24, 25, or 30 FPS
If you know at which frame rate you shot, it is best to encode at that same frame rate. However, if it exceeds 30 FPS (frames per second), you should encode your video at half that frame rate. For example, if you shot 60 FPS, you should encode at 30 FPS. If you're uncertain what frame rate you shot at, set it to either "Current" or 30 FPS. If there is an option for keyframes, use the same value you used for frame rate.
Data rate 2000 kbps (SD), 5000 kbps (HD)
This setting controls both the visual quality of the video and the file size. In most video editors, this is done in terms of kilobits per second (kbps). Use 2000 kbps for standard definition or 5000 kbps for high definition video.
Resolution 640x480 (SD), 1280x720 (HD)
640x480 for 4:3 SD video, 640x360 for 16:9 SD video, and 1280x720 or 1920x1080 for HD. If you have the option to control the pixel aspect ratio (not the display aspect ratio) make sure it's set to "1:1" or "1.00", sometimes referred to as "square pixels."
Deinterlacing Maybe
If you are shooting on an older camera, enable this option. Otherwise, you may get weird-looking horizontal lines in your video. With newer camera models this won't matter, so you can leave this option unchecked.
Audio Codec AAC (Advanced Audio Codec)
For best results, we recommend using AAC for the audio codec.
Data rate 320 kbps
320 kbps is the highest quality audio data rate most video sites currently support.
Sample rate 44.1 kHz
44.1 kHz is the highest audio sample rate most video sites support
Sample Clip
Filmed on a Canon T2i, with color settings on the camera a bit off. But you can achieve such clarity with any camera if you follow these guidelines
http://vimeo.com/34430335
Deinterlacing Maybe
Data rate 320 kbps
Sample Clip
