- Thu Feb 25, 2010 12:20 am
#177557
i looked at the source code for the site, he is all over the place when he was making it.
easiest way to change it is, open index.html in notepad, and you will see this. dont mind the mumble jumble, just the bold part. if you change that to what ever you want, it will show on the webpage. change the name on all pages and re-upload.
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<script type="text/javascript">
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<style type="text/css">
body {
background-color: #000000;
</style></head>
<body onload="MM_preloadImages('13k.jpg','websitefront.jpg','websiteindex.jpg')">
<div align="center">
<table width="200" border="0">
<tr>
<td><a href="about nl.html" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('Image1','','websiteindex.jpg',1)"><img src="websiteindex.jpg" name="Image1" width="598" height="591" border="0" id="Image1" /></a>
<div align="center"></div></td>
</tr>
<tr>
<td> </td>
</tr>
</table>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
</div>
</body>
</html>
Honda: making pizza delivery profitable since 1977.
