Page 4 of 4
Tue May 20, 2014 2:38 pm
by jedrick
ok so everything is working, but i have a leak , the system holds vacuum but it empties out i put some dye in the system but i cant find the leak, any ideas where i should look?
it holds vacuum but in less than i week my system had no freon, ideas?
Tue May 20, 2014 2:57 pm
by Leppy
I had an issue like this once. Is the system R-134 from the factory, or has it been converted from R-12?
I had a leak I couldn't detect for the longest time. Turned out to be a leaky valve in the conversion kit. I had to fiddle with mine before it sealed, but what I really need to do replace the screwed on parts.
Look for dye around the valve when you pull the caps off, or look for bubbles. If it's a strong leak, you'll see it bubble out. If it's a slower leak, you could spray some soapy water on it and it'll bubble.
Tue May 20, 2014 3:28 pm
by jedrick
No I haven't changed it, Its factory R134
Tue May 20, 2014 3:40 pm
by Leppy
jedrick wrote:No I haven't changed it, Its factory R134
Still couldn't hurt to check the valves for leaks either way. I've had to replace a few when I worked at the Honda dealership on R134 systems.
Other common places i've seen leak are the o-rings connecting the lines to the compressor and the condenser.
Tue May 20, 2014 3:49 pm
by jedrick
When u say the valves as r u talking about the one that goes from cold to hot? That moves if u move the slider from the inside?
Tue May 20, 2014 4:10 pm
by Leppy
jedrick wrote:When u say the valves as r u talking about the one that goes from cold to hot? That moves if u move the slider from the inside?
These things. They are screwed inside under the caps on both the low and high side. They are exactly like the valves inside the valve stems in your wheels/tires.
Sometimes they back out, and sometimes the seals fail.
Tue May 20, 2014 4:25 pm
by jedrick
I have replace those they are brand new and I have tested for leaks they r good, is it possible that is leaking inside the box under the dash? In the blower fan area
Tue May 27, 2014 9:34 pm
by jedrick
Is it possible? The above question? I have used 2 12 oz freon cans with dye and straight dye and can't find a leak
Wed May 28, 2014 6:01 am
by bigJOE671
You should use a freon Detector. It's faster than looking for dye. Some AC places might have them.
Fri Jul 04, 2014 4:23 pm
by jedrick
So I gave up on playing ac repair man, took it to a shop and they told me it was the compressor, bought one last week and it just arrived, let's see if they were right
Sun Jul 06, 2014 3:05 am
by jedrick
Should I drive the car after installing a new compressor or should I wait until I vacumm the system?
Sun Jul 06, 2014 3:15 am
by Leppy
jedrick wrote:Should I drive the car after installing a new compressor or should I wait until I vacumm the system?
If the system is sealed, it's ok as long as you don't actually TURN ON the compressor. Keep the A/C button off until it's vacuumed and recharged.
Sun Jul 06, 2014 3:20 am
by jedrick
OK tyvm
Wed Jul 09, 2014 8:53 pm
by jedrick
OK so I opened up the old compressor and it was completely shredded inside, I'll post a pic later, Now I need to ask u guys I put 2 oz of pag 46 in each hole in the compressor is this OK or wrong? And I'm not sure which hole I put it , in the dryer and I put about 1 oz and 1/2 in it , doesn't the oil go thru the entire ac system? Does it matter which hole
Wed Jul 09, 2014 9:18 pm
by jedrick
And FML, the system is not holding a vacum
