- Fri Dec 18, 2009 7:03 pm
#162778
I am selling my Hatch
-1993 Civic DX
-1995 Civic Si drive train D16Z6, S20 Transmission out of and EX
-Vitara turbo build
>Vitara forged pistons
>Eagle H Beam rods
>Cleavite bearings
>ARP Rod studs
>Notched block to clear rods
>Balanced crank
>New oil sump
>Cometic MLS head gasket
>ARP head studs
>Factory rebuilt head
>Factory cam
>AEM adjustable cam gear
>Gates racing timing belt
>New tensioner
>New water pump
>New oil pump
>Unorthodox Underdrive crank pulley
>Factory fuel injectors
>DSM Blue top fuel injectors (450cc)
>Resistor box ready to be connected for the injectors
>Rams Horn equal length turbo manifold w/ center wastegate port
-ACT 11lb Flywheel
-Exedy Stage 2 Clutch
-Walbro 255 Fuel Pump
-Rebult Transmission with OEM Honda syncros and bearings
-Urethane engine and transmission mounts
-Mobil 1 5W-30 since I've owned it and since build
-Mushimoto dual core radiator
-Older Speraco huge intercooler (just fits between the headlights)
-STS turbo oil pump with external oil cooler (steel & aluminum)
-Virgin P28 ECU
-"JDM" Intercooler piping and couplers
-Drop Zone coilovers with Ground Control shocks
-Neuspeed upper strut brace
-Neuspeed short throw shifter
-Si rear disk brake conversion
-2002 HY35 Turbo (needs to be rebuilt)
-Comes with 4 Bosch wide band A/F sensors (just need gauge)
The Bad
Has typical Honda rot in the rear quarters. I have the replacement quarters for both sides.
I got weird in college and installed an Integra font end on it. So now there is a new Civic core support, fenders, front bumper and a used hood. Still needs headlights, corner lights, hood latch, hood cable and a tune to be complete. Also as you can see by the pictures that the whole car needs to be painted and some dings and dents fixed.
All the windows are good on the car except for the front Windshield. This will most definitely need to be replaced.
I'm looking to get $2000 OBO out of this being that there are 0 miles on the engine after the build. The body has roughly 200,000+ miles on it. All suspension parts have been very well taken care of.
I am also up for trades for a quad. I'm specifically looking for a well maintained Honda 250R or a decent Honda 450R. But let me know what you have and I may consider it. PM me if interested. I have the pics on a phtotbucket account. The only difference between the pics and now is the interior is all back in.
http://s875.photobucket.com/albums/ab311/mebanks02/
Thanks
Mat
Located in Royal Oak, Michigan
-1993 Civic DX
-Vitara turbo build
>Eagle H Beam rods
>Cleavite bearings
>ARP Rod studs
>Balanced crank
>New oil sump
>ARP head studs
>Factory cam
>New tensioner
>New water pump
>New oil pump
-ACT 11lb Flywheel
-Virgin P28 ECU
The Bad
Thanks
Mat
To Them, they're just vehicles. To Us, they're a way of life.
