- Sat Sep 24, 2011 4:07 pm
#274208
For the light to be always on, the signal wire must be permanently grounded. Does your light have a switch on it? If so, then it's probably wired to ground instead of to the latch.
- Sat Sep 24, 2011 6:31 pm
#274236
That's the thing though. When I installed the light it worked perfect. It would turn on once I popped the hatch glass and off when I closed it. Later down the road, the festoon went out and I ignored it since I wasn't really needing the light. When I finally went to replace the bulb it ended up staying on for a few hours because I changed it in the day. I didn't notice that it was on till later that evening when I saw the rear glowing. It would turn off with the switch but not with the hatch glass closing.
- Mon Jun 11, 2012 1:17 am
#307906
i just did this using the trunk light from my old lx sedan . only thing i found off was the trigger wire in the diy says green/black wire, did that and light stayed on. in my 92 vx the right wire was green with silver dots. works great now
- Fri Jun 15, 2012 2:45 am
#308302
There will be slight variations between models and that's why you must always verify all wires with a multimeter.
Thanks for the info!
- Tue Aug 14, 2012 12:52 am
#313421
Just did this yesterday thanks for the write up suspendedHatch, i also had to tap solid green wire with silver dots for the light to work with the hatch opening. I have a 92 cx, just wanted to share because everyone who googles "hatch light install" is brought here.
- Thu Dec 13, 2012 3:50 am
#322136
Doing this soon! Thanx
- Page 3 of 4
- 1
- 2
- 3
- 4
