- Fri Feb 13, 2015 2:28 pm
#351848
I start up my car but my guage shoots up to 4K ..what could cause this. Can someone help me with this. I've tried turning the idle down but that didnt work..
- Fri Feb 13, 2015 3:02 pm
#351849
Could be a few things. Do you have any MIL codes?
Stuck throttle plate, bad idle air control (IACV), bad fast idle control(FITV), big vacuum leak(ie: throttle body gasket or brake booster hose), bad/stuck TPS, Throttle stop screw moved(This is the one under the gold throttle wheel that has a small nut and allen key in it).
Also here is a link with all the info you could want on the IACV, FITV, and Honda PGMFI idle control.
http://ecomodder.com/forum/showthread.php/honda-iacv-explained-967.html
