- Wed Nov 06, 2013 7:37 pm
#338463
I just bought a VX for a daily driver. Can't drive the STi every day. It's just too much car! lol
I disagree with putting aftermarket suspension on a daily. I prefer something comfy that can handle all conditions ie stock. I'm going to try putting ITR springs/struts/lcas on the VX, only because I already have a set sitting in the garage. Hopefully it doesn't jack the car up any higher
I recommend an alarm/keyless entry, kill switch, ipod stereo, oem cruise control swap, Integra front seats, Integra sway bars, gsr front strut tower brace, Integra front lower brace, rear disc brakes, trunk light, clock, door chime delete, headlight chime addition, VTAK! light, tilt wheel swap, multi-speed wiper swap.
Make some mdf mounts for the front speakers, run upgraded speaker wire into the doors, and apply a dynamat speaker kit.
Do the extended maintenance including ignition timing, steering rack adjustment, valve adjustment, clean out the intake manifold, seafoam, clean out the blower motor / AC evaporator, tighten the throttle cable, bleed the brakes and clutch, lubricate the caliper pins, and tighten the parking brake lever.
Strip some weight off of it:
front and rear 5mph bumper supports
intake manifold bracket
driver's knee bolster
lower ignition shield
intake resonator box and warm air intake
rear speakers
airbag system (to remove the airbags themselves you'll want a new steering wheel and a dash block off plate for 94, 95)
