- Wed Nov 21, 2012 11:41 pm
#320578
DIY: 96-98 Rear Wiper Delete
Required tools
-Flat screwdriver
-10mm socket and rinch
First step: Remove the plastic cap on the rear wiper.(Watch not to break it!)
Step 2: Remove 10mm nut with the rinch.(as seen in picture below)
Step 3: Remove wiper. be carful not to hit your window when removing the wiper.
Step 4: Remove rubber sealer. (twist and pull)
Step 5: Open trunk door. Remove the 2 little plastic pins under de trunk where the trunk latch is located (push in the middel of the pins to make them unlock then pull in the outter area of the pin)
Step 6: Before removing the Door panel located all the plastic pins on this picture below . (Help to remove the panel without breaking it)
Step 7: Remove plastic panel carefuly not to break it and be careful not to break the lock pin too!!!
Step 8: Unhook the motor from the body. (small plastic connector)
Step 9: Take your 10mm socket and remove the 3 bolts And remove the wiper motor.
Step 10: Get yourself a rubber hole plug or the password JDM aluminum plug.(If Password JDM product Read proper instruction to put the aluminum plug) Then Put back your plastic panel (don't forget to put your 2 pins near the truck latch ) and your good to go! [/u]
Required tools
-Flat screwdriver
H old
O n
N ot
D one
A ccelerating
O n
N ot
D one
A ccelerating
