By HeikDiesel
#315616 Is there a logical reason why you want to install them? The holes for the clips are square and then there is one bolt for the long strip down the door. There would be quite a bit of labor involved to cut all those holes unless you buy used parts from a car that came with them
By FG2_Andrew
#315623 get some 3m double sided, badass tape. do NOT drill. you'll run the risk of severe RUST.
By HeikDiesel
#315639 hmm, never seen the tape ones, good info guys
By Eg6H2D
#315640
JUICE wrote:Password JDM sells the stick on thin side moulding kits
Yes and if anything! look up 3M tape. and get the right one that is for Body and resists heat peeling and chemicals. ! they have it just cant think of the right one right now
By jadeydrag0117
#316290
DTR808 wrote:Any body know how to install side moldings on an eg that dosnt have the holes for them :?
buy new doors, or junk yard
and there is such a thing as the sticky side moldings that are the thin jdm moldings. its called TAPE and the other is called CLIP
http://www.passwordjdm.com/sitemap/p/Pa ... e-1321.htm
By FG2_Andrew
#316307 Buying new doors won't help. Then he has to buy new fenders AND cut holes in rear qp
By jadeydrag0117
#316309
EH2_andy wrote:Buying new doors won't help. Then he has to buy new fenders AND cut holes in rear qp
oh yeah huh....sorry
By DTR808
#316642 thanks for the feed back guys i didnt know about those tape ones ill look them up on password
