- Tue Aug 14, 2012 3:00 pm
#313475
We went with what was posted under the hood, which matched what I found online.
"Anything less... is everything else"
suspendedHatch wrote:Be careful because the base ignition timing for the VX is unique and often reported to be 16 when it is in fact 12. The only spec you can rely on is the label on the underside of your hood once you've verified the VIN to make sure it's the original label.
