- Mon Jul 16, 2012 4:17 am
#311060
Its sounds like you have alot of learning to do.
Here's What you should do:
Read this guide on how to check the CEL codes:
http://check-engine-light-codes.blogspot.com/2006/04/honda-1990-1995-obd1-code-retrieval.html
Then make sure you have a piece of wire or something in your car. Drive around until you get the Check engine light to come on. Once it comes on pull over and stick one end of your wire in one of the holes on the connector and then stick the other end of the wire into the other hole. Watch the CEL on the dash as it flashes and count following the rules/steps in the guide. If it throws a 17 (One long flash followed by 7 short flashes) that means its your Speed Sensor.
The Speed sensor is on the back side of the transmission (left side of your engine bay) way down there. Check that out see if its plugged in, maybe it got wet and fried itself who knows.
Good luck
