- Sun Apr 29, 2012 1:11 pm
#303265
i have problem, door won't unlock. door opened while i was driving, so i stoped, locked them and continued to drive. when i stopped i couldn't unlock door. central look is working, i hear it, but it doesn't unlock. i can't unlock it with the key, key won't turn, same from inside. it's passangers door. any ideas what to do? how can i remove door panel with closed door, or whatever i can do to solve this problem. thanks in advance
- Sun Apr 29, 2012 6:07 pm
#303284
can you open the door or is it locked close?
- Mon Apr 30, 2012 6:09 am
#303336
couldn't you just remove the door handle trim (interior) and pull the lock by hand?
- Mon Apr 30, 2012 3:42 pm
#303374
i did that, but i couldn't open the door, something is stucked. lock moves a little bit when i push it by hand. same when i central lock unlocks it. something is blocking door to unlock. the rod from door lock handle is connected, but i cant push it.
- Mon Apr 30, 2012 6:07 pm
#303391
Door opened while the car was moving? Sounds like the lock failed. Then when it was shut, it probably got jammed up. It's going to be tough to get the inner panel off with the door shut b/c the dash is in the way.
When you pull on the handle, is there any resistance? This is a tough one... Maybe someone pulling on the door on the outside and someone pushing from the inside while you're opening the handle? This is IF it is indeed a jammed lock...
- Mon Apr 30, 2012 7:52 pm
#303399
yes, door opened when i was turning left...luckly i didn't hit anyone
i stopped, but i couldn't close the door, door wasn't holding, so i had to lock it to hold the door in place. but when i wanted to unlock it, i couldn't. i can't turn key or pull lock switch from inside.
- Tue May 01, 2012 1:05 am
#303422
Locked or unlocked, a door doesn't come open unless the latch is broken or disconnected. If you ever loosen the striker or latch, and then don't torque them down afterward, they will vibrate loose.
This is going to be tough. It may be cheaper to take it to a body shop then to cause damage to the car. I would keep f'ing with it and hope you get it open. Failing that, I would look to how you can get it with causing the least amount of damage. You could take a hole saw to the outside door handle cover, or you could rip apart your door panel. Neither of these is a guarantee you will be able to fix it.
Here's an idea. Take off the rear quarter plastic and try to unscrew the striker using vice grips on the backside of the screws. I don't know if it's even possible, but the only damage would be to the two screws and you're guaranteed to get it open.
- Wed May 02, 2012 10:13 am
#303603
problem solved!
outside door handle rod felt out of it's place and got stucked, so it was blocking door to open mechanicly.
door panel can open with door closed. first i lowered window. then i took off handle trim plastic and window switch, grabbed door pocket and pulled out lower side of panel. it popped out, then i pulled it little up. door panel can bend enough to see all without posibility to break. then i closed window, and moved to back seat. problem was obvious when i saw that rod falled from it's place. i put all back and it was it , all working
thank you all for advices
- Wed May 02, 2012 12:55 pm
#303609
good to know that can be done and that the fix was an easy one
