By DJA
#296713 I'm sure this question has been asked a billion times. I bought a totalled 99 LS integra and i am gonna swap the motor in my 93 hatch however i have never done this. i know what i need to do the basic swap what i dont know is what all i need to have so i can have it Barr'd / Reff'd to make it california street legal. How do i add the OBD2 test port and what not. I do not know electrical very good so i just have absolutly no idea what to keep or what to swap when dealing with harnesses and what not. Please help me out with any info you can. Thanks.
#296716 I don't know cali law but converting the entire car to OBD2 to have the test port on an OBD1 car is going to be a major project if you have little or no experience in automotive wiring.
By DJA
#296720 Well whenever they do a smog on an OBD2 motor they always plug a code reader into the test port to make sure there are no codes coming up.
By DuckIt
#296724 Convert the motor to obd1 and run an obd1 ls ecu.
Should be able to use most of the sensors off your obd1 d series.
By DJA
#296726 i thought about that i'm just not sure if the smog ref will pass it or not, guess ill have to do more research on california laws.
Thanks for the help, i appriciate it.
By Wicked
#296729 You wont pass because the motor's serial numbers register the motor as a OBD2 engine and your vehicle is OBD1. Only way around it is to do a conversion to OBD2 and get it reffed.
By DJA
#296740
Wicked wrote:You wont pass because the motor's serial numbers register the motor as a OBD2 engine and your vehicle is OBD1. Only way around it is to do a conversion to OBD2 and get it reffed.
Well i have the entire spare car that i can pull parts from. What all do you think i need to convert the it over to OBD2? Is it really that hard to do?
By DJA
#296752 I really want it to be a fully legal california swap.
