By Pimpeg6
#295979 Hi, im just new to this forum. My brother just totaled his 97 gsr and i was planning to swap the engine into my 92 civic si. i was wondering if i can reuse the obd2 engine harness with the ecu. And what else would i need to make this work in my 92 civic si. Thanks for helping.
By asianrob
#295982 you'll need to use your existing harness and use a OBD1 P72 (other ecus may work lole P30 or Chipped P28 just depends what you are looking for)
while you use your existing harness you'll may need to extend some wires and etc. but nothing big.
you can use 94-95 GSR wire harness too if you can find one.
you can either repin that Distributor or get a adapter harness for it. or find an OBD1 B series Vtec Distributor.
www.rywire.com should have that adapter harness
