- Tue Mar 08, 2011 6:45 am
#242884
Last night as I was driving home from work a few blocks away my interior lights went dim. As I turned on my turn signal the RPM gauge was acting erratic, but my car was drivable. So I get home and tried to restart my car and no go. I wait a few minutes then my EG turned on with no problem. I turned off my car and restarted it a few times but this time the battery light kept coming on and off. Could this be the battery, alternator, or and electrical problem???
- Tue Mar 08, 2011 1:57 pm
#242912
Anyone???
- Tue Mar 08, 2011 2:22 pm
#242915
alternator....
Team XXX Racing/WGHonda
- Tue Mar 08, 2011 3:11 pm
#242928
yeah, alternator wasn't charging the battery. Battery bay be able to be charged but it sounds like the alternator is toast unless it's just an unplugged/loose wire or the belt fell off.
My 1992 SOHC Turbo Hatch
- Thu Mar 10, 2011 11:21 pm
#243390
U can always take ur ALt to a Autoparts and they can test it for you..Well thats what u can do over here in Cali if u take it to a Autozone or Kragens/ORileys... U can also clean the contacts inside the Alt if u wanted too.. But check the Wiring first to make sure. I had my wire come loose on me and had the same problems. The Battery light would light up and then go away after I hit a bump. So check that first and then let us know..
Hope that u get it fixed!
- Wed Mar 16, 2011 11:01 am
#244232
I had the same thing but a friend of mine,mechanic he is,he said that it was a battery issue cause my car was not moving for like a month or so so the battery needed recharging...i did recharge the battery no problem getting it on and off,my lights work properly now and all probs solved
I cant believe the gas price is 1.70euros per liter...And im still driving...i still searching for the B18 swap
- Wed Mar 16, 2011 3:18 pm
#244250
i agree with punksz6, make sure you start out cheap dont just go and buy an alternator, test the battery first and if thats good then test the alternator and also check fuses. sometimes it might be something that simple.
any reputable parts store i.e. auto zone, advance auto, oreileys all will do these test free of charge
good luck
good luck
- Thu Mar 17, 2011 5:49 pm
#244497
if you have a multimeter you really just need to check the voltage across the battery while its running, with a good alternator it should read in the 13.7-14V range
94 Civic Hatch - B16A+bolt-ons+suspension
95 Civic Hatch - Totaled ^Donor
99 Civic Coupe - Turbo D16 - stolen '07
89 Civic Wagovan - Beater
- Tue Apr 12, 2011 11:28 am
#249931
id go get it tested at your local parts store they will tell ya your weak spot when they charge battery and alternator. also always make sure your grounds are good and getting good contact.. stupid simple problems are what i always run into
- Mon Apr 18, 2011 9:04 pm
#251036
Idk I just changed my battery
One of my terminals was loose, I knew it was
On my way home and had the same thing happen to me
Every bump I hit, all of my lights would flicker. Dim and get brighter
My needle was freakin out
Once I tightened the terminal it never happened again
Edit: For you battery to benefit from your alternator you need to drive about 15 miles.
Your lights:
Cycle your ignition before starting
Wait until your srs and cel turn off on your cluster
Then start your car
If the battery light is still on then its your battery
Doing this is also using your fuel pump and 02 sensor properly
Your lights:
Then start your car
