- Fri Nov 26, 2010 7:36 pm
#224747
I was wondering, since i have a 94 del sol dohc vtec laying around, would the exhaust piping from front to rear bolt straight on my eg hatch? need to know asap...did some research but came with no threats results on this issue!
- Mon Nov 29, 2010 11:10 pm
#225095
if the eg has a b series engine then the manifold and downpipe will fit from the del sol but if the eg has a d series then no it wont but the center section im not to sure about i no the chassis on the del sol and the eg's are the same it should all bolt up together but its mounting on the rubbers that might be in diffrent places. my advice would be to get the car on a steady jack and check if all the mounting brackets are in the same place.
- Mon Nov 29, 2010 11:33 pm
#225099
+1
I would definitly check for the mounting locations.... all the bend should be exactly the same.
tq2ugetme wrote:if the eg has a b series engine then the manifold and downpipe will fit from the del sol but if the eg has a d series then no it wont but the center section im not to sure about i no the chassis on the del sol and the eg's are the same it should all bolt up together but its mounting on the rubbers that might be in diffrent places. my advice would be to get the car on a steady jack and check if all the mounting brackets are in the same place.
+1
CMDeOro 1993 Honda Civic DX Build Thread
http://civic-eg.com/viewtopic.php?p=208613#208613
Go Heat, Go Dolphins and Go Marlins!!
- Tue Nov 30, 2010 12:08 am
#225107
The center exhaust section in a Del SOl is shorter than the center pipe in a EK Hatchback.
Helped a buddy move his B20 from his EK hatch to a Del Sol.
Had to have the center pipe shorted 11 and 1/4 inches to fit the Del Sol.
- Tue Nov 30, 2010 12:22 am
#225108
I think he said eg...
Datsmart wrote:The center exhaust section in a Del SOl is shorter than the center pipe in a EK Hatchback.
- Tue Nov 30, 2010 3:37 am
#225135
it might be a bit short
and I had a GSR coupe exhaust on my 1 of my sedans and it bolted straight on to my D series header.
92 civic cx sold!!
white 92 civic Si (traded)
primered 94 teg sold
92 civic DX sold!!
93 red EX coupe parted out!
92 civic LX sold!!
90 240sx sold!
93 faded black EX coupe
92 civic DX sold!!
92 civic LX sold!!
90 240sx sold!
- Tue Nov 30, 2010 8:03 am
#225177
Delsols wheelbase is a bit shorter then the EG hatch so it will probally be a little short.
Also if you have the Rare Delsol VTEC lying around why arn't you building that instead of a EG Hatch?
2017 Chevy BoltEV DD |2001 Honda CRV SE
- Tue Nov 30, 2010 3:26 pm
#225205
+1
build the del sol dont see many around with a b series.
chrono404 wrote:Delsols wheelbase is a bit shorter then the EG hatch so it will probally be a little short.
+1
- Wed Dec 01, 2010 4:55 pm
#225428
yea that what i was thinking but the delsol had a front end collision, which i took off the radiator support...know its just laying around, recently just bought a jdm del sol front bumper and radiator support...anyway i suppose i better off at the shops getting a new 2.5" pipping...but thanks guy, that was helpful
- Wed Dec 01, 2010 5:00 pm
#225430
hey does anyone have any picture of the two together?
