- Sat Jun 30, 2007 10:04 am
#12704
We'll, we've gotten our first season completed, and are nearing halfway through our second so I thought I'd update our setup.
EXTENSIVE Driver Development (see below)
Kumho V710's 195/55 (30F/51R)
Isuzu I-Mark RS (w/Lotus Suspension) alloys (roughly 10.5 lbs. each)
Koni Sports (full soft F / full firm R)
1/16th toe out F and R
Energy Suspension FSB poly bushings
K & N panel filter
eBay can
Castrol Syntec (crankcase)
Red Line MTL (tranny)
MSD wires
I remove the cargo cover, spare tire and tools, and everything else from the passenger compartment. I also run with about 1/8 tank of fuel now.
Yet to come...
22mm FSB (with ES bushings!) from a 'teggy LS ($40)
Custom mandrel bent cat-back exhaust (open to suggestions on diameter...help?)
By the way, the car now averages 40+ MPG...as high as 42!
Here's the car a little earlier this year. This was my first win!
So far, this has been an awesome year. I've won 4 events, lead our club's Day Series points championship, am second in our Nite Series points, and second in points with another club's mini-series. I also generally finish in the top 10 in PAX, and have finished as high as 4th PAX.
Last season, my best finish was 2nd, but around 2 full seconds behind the leader. I also generally finished mid pack in PAX, sometimes cracking the top third of the field.
How the dramatic turnaround? Driver development, plain and simple. I don't write this to brag, but to tell you HOW I improved.
From February to May, I attended 4 driver's schools (including Evolution Phase I). Between the schools and several events, I logged roughly 150 autocross runs. That's about the number of runs the "average" autocrosser gets in THREE YEARS. Not only was this a ton of seat time, it was high quality, instructed seat time by Nationals level drivers.
The EG, in my opinion, is an EXCELLENT platform for many autocross classes, including H Stock, STS, and the Street Prepared classes. A friend, and mentor, regularly sets FTD (Fastest Time of the Day) in his FSP EG hatch.
Further, all the EG models compete in the same Stock and STS classes. I'm not so sure that non-Si models don't have a slight advantage over the Si, at least in some areas. Although the Si gets several factory upgrades, it puts on a good deal of weight over other models. Plus, the Si goes into DSP (when appropriately modded) and has to run against the BMW 318's. Other EG's go into FSP where, I think, they're more competitive.
Whether you've done a full JDM GSR swap, or you're bone stock as I was, find an event and have FUN!
Post up your thoughts, set-ups, and experiences!
Remember..."Civic spelled backwards is "civiC"
