Ride of the month nominations & voting.
Whose Civic should be Ride of the Month?
7
41%
8
47%
2
12%
#348755 1. JUICE
Exterior/Interior
-All new steel full quarters/rockers, RUST FREE!!!
-13" Exospeed VPD w/ Mickey Thompson 24.5x9x13
-LS Meshies rear
-CCC Racing Street drag wing
-Custom Welded in 6 point cage
-TPR rear diffuser
-rear interior gutted
-LS seats w/ 5 point RCI cam lock
-ARP extended wheel studs
-VX pass mirror delete
-Taylor Battery box relocation kit
-Moroso Kill switch thru tailgate keyhole
Suspension
-Omni Drag coilovers
-Skunk2 12k front 18k rear springs
-Full-Race Pro Am Traction bar
-Skunk2 front camber kit
-Skunk2 LCA's
-Energy Suspension bushings
-99 integra rear disc swap
-Corner Balanced 65/35 by Turn-in Concepts
Engine / Drivetrain
-ERL Darton Sleeved 84mm B18b1 block
-ERL 5-point main girdle
-ARP main studs
-CP Turbo Pistons w/ coated skirts
-CP Piston rings
-Manley Turbo Tuff Rods
-ACL Race/Calico Coated Bearings
-polished LS crank
-ATI Race Damper crank pulley
-Moroso Oil pan
-BES ported B16 head
-Supertech Ti dual springs
-Supertech valves
-Bronze valve guides
-Crower retainers
-Skunk2 Pro 1 Cams
-Golden Eagle Cam Gears
-Gates Racing Timing Belt
-JG Edelbrock Intake mani
-Port matched 3" TB
-TPR fuel rail/lines
-GSR transmission
-Quaife LSD
-Speedfactory SCHA
-Synchrotech carbon synchros
-Competition Clutch Twin Disk
-DriveShaftShop 2.9 axles
Turbo Components
-Precision SC6162 re-housed by PureTurbo's
-Precision 46mm Wastegate
-MAC Electronic Boost Solenoid
-RC 1000cc Injectors
-Walbro 255 pump
-SLS T3 Top Mount manifold
-SLS 3" Downpipe
-Tial Q 50mm BOV
-Custom 2.5" / 3" Intercooler piping
-GodSpeed 31"x12"x3" FMIC
-BlueRidge Motorsports battery tray Catch Can
Made 547whp @ 22 psi on 112 octane race gas. Tuned by Dave Blundell (Blundar) on NeptuneRTP.
dyno vid- http://www.youtube.com/watch?v=LOu-HUJNl6Y&feature=share&list=UUV8RIduW1yw6n0WesXbZ72w
2. Teal_dx 1992 Civic Dx
Body/Exterior:
JSP CF Hood
VIS CF Tail Gate (sold, back to stock)
DIY Army Green/Black roof paint job
Shaved & tucked engine bay
DIY Amber corners
VX rear diffuser (not yet installed)
Engine:
D16z6
SRP 75.5mm forged pistons
Eagle Rods
ARP Head studs
1999 D16y8 intake manifold
knockoff AEM fuel rail
AEM fpr
DSM 450cc Blue top injectors + resistor box
Motorola 2.5 bar MAP
Walbro 255 LPH
stainless fuel line, -AN fittings, inline fuel filter
Custom K&N for clearance
Auto to Manual conversion mount
OEM mounts urethane filled
Turbo:
Garrett T3 .60/.48 60 trim internal WG
Cast manifold
2.5" Spoolin DP
3" Thermal cat back
2.5" piping & FMIC
Hallman manual boost control
knockoff HKS BOV
Function 7 -AN downpipe flange & fittings
Oil Sandwich Plate Adapter
Custom K&N Air Filter
Si transmission:
OBX LSD
XTD stage 3 6-puck clutch
8 lb flywheel
braided stainless clutch line
Interior & Electronics:
EX Gauge cluster w/ Tach
Autometer Oil pressure, Boost, EGT gauges
Odyssey PC680 battery
slim push fan
4ga and 8ga custom wiring for electrical system
P28 chipped with Hondata S300
Suspension:
Tokico HP struts/CR coil overs
Energy Suspension Master Bushing Kit
Energy Suspension Trailing Arm Bushings
Suspension Techniques 22mm front & 19mm rear sway bars
ASR A-Spec subframe brace
Wheels/tires:
polished 14" HX wheels
195/60R14 Falken Azenis RT615
2-piece 15x7" +18 r, 15x6.5" +23 f Work Euroline S2H Wide on 195/50R15 Falken 912's - SOLD
Forged 15x7 +32 OZ Racing Starlights on 205/50R15 Nittos
Brakes:
EBC Greenstuff pads (not yet installed)
EBC slotted/drilled rotors (not yet installed)
SS brake lines
3. rtegra92
up is the J SWAP
J35 bottom end
TL Type s heads, intake and throttle body
TL type s Trans.
Godspeed t67
big doushin intercooler
greddy BOV
godspeed wastegate
ALL piping and stainless work done by yours truly.
Innovate lc2
innovate Ot2
extra fuel provided by two 1600cc bosch injectors
controlled by an additional injector controller
rota attack 15'
eibach springs
shift plate also made from stainless by yours truly.
By Axix23
#348774 Voted for tealdx! :)
By Apexracing
#349049
teal_dx wrote:Well congrats Teal, you won! (and I didn't even have to rig the voting) :D
This means you have to keep the car :wink:
