Appearance, Paint & Body Work
By rmp705
#311816 is there a way to stop my driver side from leaking into my car?
also when driving down the highway is there a way to not have water come in the cab when the windows are down?
thank you
#311841 FOr your first question, where is the water getting into your car? Find the source of entry and we'll go from there.
For driving with the windows down, you could get a set of vent visors but they will only help if the windows are down a little bit.
:thumb:
By hondamonstercrew
#311842 My bets are on your window rail is slightly warped seems to be a common issue with the where the window slides to just outside the rubber at the top of the door if this is the case there is a d.i.y to fix and reinforce the rail
maybe im wrong but hey worth a shot
and part two im with teal wind deflectors is as good as it gets :thumb:
