- Thu Jun 12, 2008 10:43 pm
#58262
what size are the bolts to the fender? i dont have them and i need them
- Thu Jun 12, 2008 11:24 pm
#58276
10mm
- Fri Jun 13, 2008 8:35 am
#58327
80% of the car is held together with the same size. Atleast 20% will sheer.
Graham wrote:10mm
- Wed May 12, 2010 1:05 am
#193258
Thanks a lot man, my fender is all dented and everything is falling apart, fender, fender lining, splash guard bumper cover. I will replace it now!
- Mon Jan 14, 2013 10:21 am
#324061
lol this is funny >> (diy your self of course) , hire a mechanic to take off your fenders
- Sun Jun 01, 2014 9:17 pm
#346064
Anyone have any idea of getting the side skirts back on. I know or noticed the square clips have to be facing at right angles with the lip on the bottom.
I've been pushing and shoving to get the skirts on my passenger side back on after replacing the front passenger fender.
- Sun Jun 01, 2014 10:41 pm
#346067
is anything broken on your side skirts or chassis ? it should be really easy to get back on
- Sun Jun 01, 2014 11:50 pm
#346070
Nothing I can see. The side skirts popped off easily.
Am I right that all the plastic white squares should be straight and the little lip of each square on the bottom?
- Mon Jun 02, 2014 1:13 am
#346073
adjust it slide it on then, you line them all up then, hammer in it with ur palm.
- Mon Jun 02, 2014 2:28 am
#346075
Yup did that. Even gave it a little boot with my sneaker. All the holes to put the pop-screws back in don't line up like before. Will look at it agian in the morning.
- Thu Jun 05, 2014 8:13 am
#346164
Take the white clips out of the sill - turn them 45 degrees and they pull out. Then put them into your side skirt, the ledge bit goes to the bottom and there'll be marks for where they should sit. Once you've put them all on the side skirt just pushes straight into the sill
- Fri Jun 13, 2014 1:24 pm
#346426
Ah thanks didn't even think of doing it that way.
- Page 2 of 3
- 1
- 2
- 3
