- Thu Jan 06, 2011 10:32 pm
#231814
teal_dx wrote:great DIY so far!
Looking at it under the car, that front part that is 6 1/2" long might be better off not there. it looks like that might pick up some air on top of the diffuser rather than under it. I'd make it begin right behind the rear subframe.
What do you think?
u might be right, but i suppose u can go both ways, u can cut it off to the subframe or leave it alone. u can use ur template and when placing down ur sheet metal( or whatever ur using) and just stop it at the subframe, no need to cut up the template incase u wanna do a longer design.
i have a feeling ppl are misunderstanding that this isnt the actual diffuser, the cardboard piece(template) is what ur gonna use to design ur diffuser with ur choice of material.
imma need to continue my DIY, im gonna be using fiberglass on this one.
EDIT: i forgot to tell u that im not gonna have the diffuser stop right below the fuel tank, theres a bit of room to have it sit just behind so air wont go above the diffuser.
