- Tue Aug 14, 2007 11:49 pm
#19816
This is just a guide line so do not hold me responsible if you fuck it up! To make this work its all in the prep.. take your time!!!!
You will need:
- 1000 Grit sand paper
- 2000 Grit sand paper
- Automotive clear coat
- TSP cleaner
- Lots of water!! Do this outside
Here is how the wing looked before i started! all scratched and very foggy with no shine
Step 1:
In this case Im re-clearing my CF wing so it needs to be removed
Step 2:
Start WET sanding the CF with 1000 grit paper. Use lots of water
Step 3:
Once you have it WET sanded with 1000 grit rinse it off and start sanding it with 2000 grit! use lots of water
Step 4:
When you think you have got it sanded nice and smooth rinse it off and dry it well.. Dont forget to you your TPS cleaner to get off all the grease and dirt from your hands.. You could also use Varsol...
Step 5:
Apply 2 to 3 coat of automotive clear.. do not spray to close or you will get runs...
Step 6:
Let it dry a good couple of hours before you re install it. Here is the finished piece!!
Enjoy
You will need:
- TSP cleaner
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Enjoy
I <3 my Honda.
>Two.Zero< Garrett 60-1
@cdmtyper
My Build Thread
@cdmtyper
My Build Thread
