This is 15x8.5 plus 17 with 195/50r15 tires. Wheels are Klutch SL1.
Basically what you want will fit. You can't tell from this picture but the rear is something like 8 degrees of camber to fit them this low. My quarter panels and fenders are rolled and I have trimmed by rear bumper slightly to avoid the tire rubbing it. You can do the trimming with a razor blade its really easy. I got tired of how bad the car handled with this setup and changed to something that didn't have so much offset.
If you run stretched tires to get the stanced look you need to keep an eye on you tire pressure daily. Driving even a few psi low on a really stretched tire can lead to debeading which can ruin a nice wheel. Excessive stretch isn't the best idea but when running stretched tires air pressure is your friend to make sure the tire stays on the bead. Google stretched tire horror stories to see what I'm talking about. I've had several friends do it to expensive wheels.
Good luck!
