By omerdragoon
#336673 hey i have 15's i want to paint my rims i saw the diy that teal posted up i wanted to try doing that but im not sure what grids to start from and on which one should i end my rims already got alot of paint on it i want to remove i know that im supposed to use the paint remover but after that what should be the way to sand it up do tell . thankyou
#336692 I would follow the wheel polishing tutorial you are referring to. Since your rims had a coat of paint on them and shouldn't have so much corrosion, I doubt you need to start with as low of a grit as I did. Maybe one or two steps higher. Strip the paint off and post some pics here and I'll let you know what I would do :thumb:
By omerdragoon
#336954 yeah i was stuck in my exams il do it asap
