By 556lownslow
#325329 I plan on getting some diamond racing steelies but don't really want to do the whole negative camber so will I be ok running 15x6 with a 0et? I plan on rolling my fenders. Does anyone have pics or know someone rolling on this wheel size,I want a deep lip with as little camber adjustment possible I use my car for work and drive about 70 miles a day don't want to go through tires because of camber wear, but still want it to look clean. My car is slammed on springs by the way but plan on installing my koni Strt's and ground control coilovers when I get the wheels. Please someone help. Thanks
By 1-low-92-EG-Sedan
#325370 what size tires???
it will poke a bit so yull have to strech the tire a good amount prolly
check this site out..should give you a good refrence
By 556lownslow
#325404 Do you think if I run 15x7 with a 25et wrapped in 195 or 185/50's ill rub, that's including the fender roll. I just want the deep lip look with as little camber adjustment as possible. What would you recommend
