By TrailerTrash
#280027 i dont think the width or offset of the wheel has anything to do with the studs. i could be wrong though.
I do know that u may need them if u run spacers
By EJ1STYLEN
#280042 i would have thought so either. thanks
#280594 The only reason a wheel should force you to use extended studs is if the mounting surface is just too thick for you to thread on the lugnuts with stock studs.
