- Thu Dec 09, 2010 4:16 am
#226848
ya so for the dry sanding would it be safe to use a electric sander?
if not i got a block
and i plan on painting the insides black or drak grey i like how it turned out wit your HX's
teal_dx wrote:GSR's would be easy because they are more flat and only 5 spokes. Lip is a simple design compared to HX's too.
You want sand paper for wet sanding, the grey stuff.
Use a sanding block for flat surfaces because using your hands can cause you to round down the edges of the spokes. Bur for getting in tight areas or curves like on rims with a stepped lip, fingers work best.
For the fat 5's I would only polish the surface and paint the inset areas on the sides of the spokes. they are usually a rougher casting and would take forever to smooth.
