- Sat Apr 16, 2011 7:28 pm
#250734
whats up so i picked up these rims for 100 bucks but they have some cheap paint on them thats chipping... can i use that air something stripper to try and make them look how they come stock? any help will help thanks.
- Mon Apr 18, 2011 5:44 am
#250907
Well you could just start sanding on it, or use aircraft stripper. It comes in a can and you just spray it on the paint. You let it sit and then just start wiping off the paint with some paint thinner.
- Mon Apr 18, 2011 5:58 am
#250908
The best results I got from airisol stripper was using a pressure washer to remove the paint after the stipper sat for about 15 minutes
EJ2 FoReVeR. My car is a whore
build thread http://civic-eg.com/viewtopic.php?t=18655
#1 COUPE CREW MEMBER
- Mon Apr 18, 2011 7:57 pm
#251020
Aircraft strip them, then sand and repaint if you want them painted. I would go with self etching primers, filler primer, an acrylic paint (if you want a nice glossy finish) then a clear coat.
Also you could polish them. There is a how to on the forum on doing so.
1991 CRX Si (sold)
1991 CRX HF b16a (sold)
1992 Del Sol S (sold)
1992 Hatch b16a2 (current daily)
