By markie88
#243738 I have a set of 6UL wheels 15x7.5 "205/50" I'm thinking of getting a wheel spacer. As the wheel is almost hitting my camber arm. (I'll be taking pics later after work or when im free). What size should I run or is 10mm to big? and what brand?
#243742 You'll need to measure your inner & outer clearance to determine the width of spacer. H&R make a good spacer, but whatever brand you go with, a hubcentric type is the best.
By 92hatchie
#243762 um arent wheel spacers dangerous? ive heard that over time they snap n boom wheels is off!!
#243772 hubcentric wheel spacers keep the load of the wheel on the hub where it was designed to be instead of on the studs. The studs are meant to keep the wheel on the hub. :thumb:
By markie88
#243781 I checked H&R website was looking at it my wheel has 67.1 center bore and H&R has 56.1 I don't think I can use H&R?
btw my wheel has 42offest
