By JUICE
#202640 went to put a set of HX's on my friends '02 coupe and they're hitting the calipers. I'm pretty sure i can just grind some off the caliper.
question is, if i can get it to roll straight back and forth its good right?? don't wanna go out on the test drive and on the first turn have that shit bind up...
#202646 I'd recommend a 5mm spacer over grinding unless you only take off a tiny bit.
Doesn't 2002 come with a 15" wheel? stepping down to a 14" would mean you'd have a larger sidewall.
185/65/15 is stock size. So you'd need a 70 or 75 series sidewall on a 14" rim on that car.
By JUICE
#202661 it had steelies/caps on it with 185/65/14's...
the same as whats on the HX's...
there's just like i little ridge on the face of the caliper sticking out bout an 1/8th of an inch... how much do wheel spacers run??
