- Thu Jun 04, 2009 12:56 am
#120518
so i did a full conversion on my EG. i changed the front to bigger disc brakes and the back to disc by using the parts from a 98 integra LS and for some reason the rear hub assemblies arent fitting the spindel right..it remains loose and when i drive it their is a noise that sounds like the tire is wobbling. took it to mechanic and he said that he tried replacing it with other 98 integra LS parts but still loose. any ideas on what the problem could be? thanks for any help.
**oh and i got steel braided brake lines that i think are meant for ABS if that matters at all. thanks again.
