- Mon Mar 09, 2009 4:26 am
#101625
hey i guys i did a rear disk brake conversion on my eg and used all the righ parts as outlined in all the DiY's.
after putting them in i found they both needed rear wheel bearings so i bought the entire hub kits and replaced them
driver side went on no problems
passenger side i accidentally pulled the e-brake with the caliper off and the caliper wont go on the rotor anymore. i pushed the cylinder back in and even loosened up the e-brake cable all the way and it still seems to rub.
it seems to barley rub but its enough rubbing that when i drive my car around the block it heats up everything including the rim.
car still rolls but not as freely as before. all help is appreciated and NEEDED
